Author Topic: Find details about wrong connectors found by Project Integrity Check  (Read 3589 times)
Jacob Vos
I ran Project Integrity Check and get a list of 'Invalid connector' problems with as proposed action to delete them. I can choose for 'Recover/Clean' but that's a black box. I want to know where those connectors are defined - maybe I need to correct something, and simply removing them may introduce omissions in my model. Alas even the package is not mentioned by Project Integrity Check.
How can I find details about those connectors?
I suspect it are connectors that are orphans. So I thought to found those via SQL select * from t_connector, and then filter on empty SourceElement or empty DestElement. However: for all connectors those fields are empty.
« Last Edit: February 10, 2020, 08:12:56 pm by Jacob Vos »
Re: Find details about wrong connectors found by Project Integrity Check
« Reply #1 on: February 10, 2020, 11:33:27 pm »
You can't. Sparxians are silent about that. Just run that cleanup once a week. To me it never did any harm (though they do their best to make you scared using it).
P.S. And I forgot: it often remedies "strange behavior" of EA. It's like you need to steam-clean the sink from time to time to get rid of the hairs clogging it more and more.
« Last Edit: February 11, 2020, 09:51:24 am by qwerty »
« Reply #2 on: February 11, 2020, 09:22:21 am »
Generally speaking an 'Invalid Connector' is not likely to be linked to any package. One or both of the connector ends do not reference a valid object. Even if EA gave you the id or guid of the connector there's not enough information to know what the intention was.
