Author Topic: Build 1526, Strange rendering of ports and ports in ports in IBDs on the right b  (Read 4324 times)
PeterHeintz
In build 1526 there is strange behavior of ports intended to be located on the right frame border when the frame border is selectable.
The ports jump from the frame border into the frame inside pane, and when you try to fix it, the frame border moves more to the right but the ports remain within the frame inside panes. It is even somehow possible to locate the ports to the right border but having the containing ports not on the border of the containing port but somewhere within the IDB frame inside pane.
In other words the rendering of ports on the right hand side of an IDB frame is absolutely broken.
Best regards,
Peter Heintz
PeterHeintz
Reported!
Best regards,
Peter Heintz
