Author Topic: Build 1526: 'Delete from Model' missing from diagram speed menu  (Read 3492 times)
Tarja
Hi!
I was terrified to notice that there is no 'Delete from Model' in diagram /element speed menu.
That is a crucial command if you do not want to get your model into a junkyard.
Luckily I found from an older help that the command is Ctrl+Delete, and that still works.
So please, get the command back to the diagram /element speed menu.
Re: Build 1526: 'Delete from Model' missing from diagram speed menu
« Reply #1 on: February 12, 2020, 07:48:55 pm »
Again: you need to send an official feature request.
However, don't be astonished when you see other menus have moved/be delete in the next EA version :-/
