Author Topic: Keystore Service on virtual host: change of CPUs leads to Active Directory issue  (Read 5454 times)
rty
This is to warn other users who might run into similar troubles.
We have set up a Sparx Keystore Server to maintain our Enterprise Architect Corporate floating licenses using the Active Directory authentication method. Due to the limited performance requirements, we are using a virtual machine with a single CPU.
This worked well for some time. Since we experienced performance issues concerning the machine’s interactivity at boot time, we increased the number of virtual CPUs from 1 to 2. From this time on, we were unable to check out any EA license. When eventually returning to let the virtual machine use only a single CPU, everything returned to normal.
This one was rather tricky since there is no obvious connection between the cause of the error and the observed symptoms.  :o
Details of observed behaviour
After increasing the number of CPUs, EA was still able to contact the license server (using the “Test” button when entering the SSKS data), but there was no “Product” offered to select. This usually means that the user is not member of the required AD group. The Keystore Manager application was able to contact the License Service and displayed the correct number of stored floating license. Unfortuately, it was unable to show the details (list of licenses, check out time, user, valid until etc) but showed a ‘connection lost’ error instead.
The ssks logfile did not give useful hints. In fact, it was misleading. Reasserting a checked out license failed:
REASSERT FAIL, dilbert, Sparx Systems Enterprise Architect build 1513, xxxx-xxxx-xxxx-xxxx, EA Corporate Edition, SSKSAnonymous:: dilbertsmachine\dilbert,  Error: User 'dilbert' not permitted to checkout product EA Corporate Edition
Checking out licenses just failed without notice.
Since it appeared that the AD authentication no longer worked, I added a section to the auth config:
GROUP
       Name=SSKSAnonymous
       IsManager=false
END GROUP
and as expected, the KeyStore Manager was able to show the license details. However, we were not able to find any problem with the AD configuration.
It took some serious effort to analyze the situation. Eventually we gave up and had the idea to return to single CPU which turned out to solve the problem.
Modesto Vega
Build 1513 is not a 15.1 build. Have you tried the same with a 15.1 build - https://sparxsystems.com.au/products/ea/history.html.
Did you alter or made the user up? Somehow, dilbertsmachine\dilbert does not look like an AD user but a local user.
rty
No, we did not yet upgrade to 15.1. I will check this as soon our IT support feels comfortable again. ;) But since the problem also exists for Sparx Systems Key Store Service and SSKS Manager, which is at version 2.3 since January 2016, I doubt that a new client will change the behaviour. Seems as if rather SSKS Service causes the problem.
And yes, I dilberted valid hostnames & user IDs manually for privacy purposes. I am sorry if that caused any irritation. What is SSKSAnonymous::dilbertsmachine\dilbert after the malicious CPU change is AD_group_name::host_name\user_name when everything works.
Modesto Vega
You did not cause any irritation, just curious. We have a few elements in our repository created by a certain 'bmaxwell'. Trouble is that we never had a 'bmaxwell' in the team and have concluded that certain versions of Sparx have the creator hard coded  ;).
It is worth trying v15.1, just in case they have 'fixed' something on how the client communicates to the key store.
This might be due to importing model patterns. I remember there was an issue once (maybe still so today) that the original creator of the pattern was not replaced by the current user.
(Patterns are not much more then xmi imports)
