Author Topic: Cannot get tagged values to display in stereotype as attribute in stereotype  (Read 4405 times)
mse
I defined a stereotype <<NvBlockNeeds>> which extends the metaclass Class and it has some attributes that I have defined. This stereotype works just fine when I insert it into a diagram. I can set values for the attributes and everything is correct.
Now I have another stereotype <<InternalBehavior>> which extends the metaclass Activity. This <<InternalBehavior>> refers to <<NvBlockNeeds>> that I created earlier. While NvBlockNeeds shows up as an attribute of <<InternalBehavior>>, I noticed that I cannot modify the attributes of <<NvBlockNeeds>>. I just have one blank field and that is it.
Do I have to insert some relation between the two stereotypes? I thought it would be enough to just create an attribute with type <<NvBlockNeeds>>, but that doesn't seem to work.
You need to draw a <<taggedValue>> connector and give it a role name in order to see the role name as tagged value allowing to use RefGUIDs.
If you use the profile helper (why isn't everyone doing that?) you can create a new tagged value and simply select the stereotype.
EA will then make sure the required relation is created.
mse
I'll give that a try, thanks. I tried the first suggestion as well and it worked. However, it looks like I still have to separately set the attributes. However, the reference is there at least as an attribute.
