Author Topic: Calling add-in from Learningcentre toolbox?!  (Read 3924 times)
Paulus
« on: September 21, 2012, 03:33:52 am »
According to the documentation this is possible (at least 9.3) but somehow i can't get this to work. I'm following the EA help doc EA.chm::/run_add_in_functions_from_task.htm
I have no trouble with the other types like opening views or a help file. Also no trouble defining and using add-in event handlers...  So i wonder if i am missing something. Has anybody been able to get this working?
Just in case this comes up: i -have- removed trailing spaces  ;)
Paulus
Re: Calling add-in from Learningcentre toolbox?!
« Reply #1 on: September 25, 2012, 05:51:17 am »
Just for the record, I finally found the problem: i declared the function within the assembly but in another COM object...... duh!  :D
After moving the function to the class that i registered when deploying the add-in (as described in the help topic EA.chm::/deployingaddins.htm) EA was able to find it.
« Last Edit: September 25, 2012, 05:52:54 am by pmaessen »
