Author Topic: How to set AutoNum = True in Transformation?  (Read 4711 times)
pappnas
« on: September 27, 2012, 03:02:40 am »
I want to generate a DDL Schema from UML Class Diagram.
I have the following transformation script for the Table / Primary Key:
%if classStereotype=="enumeration"%
%endTemplate%
Table
  %TRANSFORM_REFERENCE("Table")%
  %TRANSFORM_CURRENT("language", "stereotype")%
  language=%qt%%genOptDefaultDatabase%%qt%
%list="Attribute" @separator="\n" @indent="  "%
%if elemType != "Association"%
  PrimaryKey
    Column
      name=%qt%Id%qt%
      type=%qt%%CONVERT_TYPE(genOptDefaultDatabase,"Integer")%%qt%
%endIf%
%list="Connector" @separator="\n"%
How to set the AutoNum ColumnProperty to "True"?
Markus
