Author Topic: Changing the Default Paragraph Font (including the colour)  (Read 6647 times)
Modesto Vega
« on: February 21, 2020, 09:52:02 pm »
Could somebody please remind me if it is possible change "Default Paragraph Font" style, which is set to Times New Roman, the font colour, and how?
P.S.: Using Sparx v13 for this project.
Re: Changing the Default Paragraph Font (including the colour)
« Reply #1 on: February 21, 2020, 10:14:15 pm »
Yes, go to the options Diagram | Appearance | Configure Default Element Fonts
Modesto Vega
« Reply #2 on: February 21, 2020, 10:25:24 pm »
Sorry Geert, I may not have been specific enough. I am referring to the "Default Paragraph Font" that is used by the document (generation) templates.
« Reply #3 on: February 21, 2020, 10:55:43 pm »
You can create your own stylesheet and modify any of the styles.
I did notice that the "normal" style sometimes doesn't behave, so I actually never use that style (I use normal2, which I created myself)
Modesto Vega
« Reply #4 on: February 25, 2020, 12:14:10 am »
Thanks Geert, this helps. In addition, it is worth noting that "Default Paragraph Font" is a Character Style, instead of Paragraph Style, and can only be edited by changing the relevant (style) type on the Edit Stylesheet dialogue.
Modesto Vega
« Reply #5 on: March 06, 2020, 09:14:16 pm »
This more or less works but still behaves oddly on our repository. We have created a new Style Sheet based on the "normal" style under \\Document Generation\User Templates\Style Sheets and made a number of modifications.
Quite a lot of the styles get updated when using Update Styles but quite often Sparx just throws a wobble (doesn't change the font colour, or the fonts themselves, it seems to have particular difficulties with bullet point lists.)
I think this is could be solved by updating normal.rtf but as per a new thread I have just created - https://www.sparxsystems.com/forums/smf/index.php/topic,44092.0.html - I don't think the instructions are working on an RDBMS repository.
Edit: Forgot to add that one of the most annoying things is that I cannot get any new styles to show in any documents, even after updating styles.
« Last Edit: March 06, 2020, 09:57:43 pm by Modesto Vega »
Modesto Vega
« Reply #6 on: March 18, 2020, 07:48:28 pm »
There are 2 odd formatting issues I have not been able to overcome. Curiously both concern bullet points. They are:
1) With the new custom stylesheet all documents are generated with tiny bullet points, including any static text in the document.
2) All bullets points from the Notes field have a 1.5 spacing, I don't seem to be able to change this 1.0 spacing.
Any thoughts on how to work around these 2 oddities would be very welcomed.
Charles England
« Reply #7 on: April 28, 2020, 06:59:14 pm »
Yes, I'm having similar problems. I'm not getting bullets at all, either in linked dpocuments or in element desriptions. The paragraphs come out as hanging.
