Author Topic: Problem with composit on Package - or how to add diagram bellow pakage  (Read 3085 times)
PiotrS24
Hi
I made metamodel with package - name BuisnessModule . I have toolbar, can drag from toolbar and all works fine.
I want to simplify working for modeler.
Below Buisness Module  I have diagram BMDiagram, that should be there allways.
Therefore, I want to create it automaticly
My meta model looks like:
https://drive.google.com/open?id=16rXthNo8zXE4bU6uj_X29kSPot0fL-yo
when I use these meta model with _makeComposit= True I get something like this:
https://drive.google.com/open?id=1Ho6kxPb5bP1jf_CNHyYQgq2Mo4s5Wsri
I just want to add the diagram under the package when putting the "Buisness Module" from the toolbar
I suppose you can't use a Package with a composite.
So is it possible to add this sub-diagram automatically somehow? Or do something to make ComponentPackage not change its operating mode?
Have You any idea on it?
Peter
PiotrS24
Re: Problem with composit on Package - or how to add diagram bellow pakage
« Reply #1 on: February 27, 2020, 06:44:13 am »
Hi Sparx   :P
If EA does not have such functionality just write that it is not there, then maybe I will use some other solution or I will do it manually
Reply welcome ...
