Author Topic: How to block the use of a stereotype within a class  (Read 3425 times)
PiotrS24
« on: February 24, 2020, 12:56:42 am »
Hi
In my meta model I have Entity(dervied from MetaClass Class) and Fields (derived from MetaClass Attribute)
It looks like:
https://drive.google.com/open?id=1F-MpnF9XCtJA5WyQZ0vauIw6xzQQP4di
Is this configuration possible:
that the Field stereotype can be used only within the Entity class attributes?
Such a blockage should probably be combined with a form for selecting stereotypes
https://drive.google.com/open?id=1xlnuWtT1hk9ENQf_W6T_UxV-Mp6v5qph
PiotrS24
Re: How to block the use of a stereotype within a class
« Reply #1 on: February 27, 2020, 06:45:25 am »
Hi Sparx  :P
If EA does not have such functionality just write that it is not there, then maybe I will use some other solution or I will do it manually
Reply welcome ...
« Reply #2 on: February 27, 2020, 06:30:09 pm »
Hi Sparx  :P
Reply welcome ...
Hi Piotr
You are posting on the user forum of Sparx Systems.
And although some of the Sparx employees frequent this forum, there is no guarantee that a Sparx employee will see or respond to your question.
If you want to address Sparx I suggest you use the appropriate form on the website or email [email protected]
With regards to your question, I don't think you can do that using only UML profiles and MDG's. You should be able to write such validation rules in an add-in though.
PiotrS24
« Reply #3 on: February 27, 2020, 10:16:28 pm »
You're right
I will follow these rules.
As for the explanation, I have been using EA for 10 years, and before that it happened that when I asked by e-mail I didn't get the answer or the times were long. That's why it turned out this way.
In conclusion, I will write an e-mail, sorry for the confusion.
« Reply #4 on: February 28, 2020, 08:42:12 am »
If it was going to be implemented you would need to add a metaconstraint with umlRole=class from your Field stereotype to your Entity stereotype.
Having said that, no handling of that constraint has been added so the best you can do is use an add-in to implement the rules you want.
