Author Topic: Geert's import-export tool for Excel 5.0 - Object library feature not supported  (Read 6812 times)
Damir
did anyone had issue with 5.0 version of Geert's Excel import/export tool https://bellekens.com/ea-excel-import-export/. I'm getting Object library feature not supported compile error in Excel when trying to import the example data provided in the tool.  (when running import without trying to change selected package in EA, issue is in function getAttributeByName in row Set getAttributeByName = attributeCache(name)
I have EA 14.1.1429 build 1429
I have Excel 2019
Running on windows 10
this does not happen in 4.2. version (I’m not having both versions open at the same time)
Thanks!
I tested this on EA version 15.1
Maybe I've used features that were not yet available in v15.
I'll check and report back.
timoc
I've been looking at this too - I can only use it reliably with one model open. If i have multiple EA instances open it seems to choose the one i opened first, not the one i opened last.
Yes, that is true. It connects to the running instance of EA.
In case of multiple instances Windows seems to return the instance that was started up first.
Damir
I'd love to use the latest version as it has support for attribute multiplicity "out of the box" which I need...
thanks
Damir
@Geert, any chance you may check this in near future?
