Author Topic: View tagged attribute or associatio at the element to which tag value references  (Read 3982 times)
Jacob Vos
As tagged value I defined:
Type=RefGUID;
Values=Component;
Stereotype=Archimate3::Archimate_ApplicationComponent;
AppliesTo=Association,Attribute;
Now at an attribute, I set the tagged value for this tag to "Dynamics AX" (which is an application component).
My question: at the Dynamics AX element, can I view that this attibute has tagged 'me'?
No, you can't. The traceability window only shows elements with tagged values that reference you, no attributes or associations.
You can see it in the EA Navigator add-in in the folder "Referencing tagged values"
Jacob Vos
Ok, thank you.
For the one who is interested, this is a query to get insight, starting from an element X with attributes, which other elements are mentioned in attribute tags at attributes of element X (so from another 'direction' than I wrote in my first post).
select t_object.ea_guid as CLASSGUID, t_object.Object_Type as CLASSTYPE, 'Attribuut' as Soort, t_object.Name as Entiteittype, Attributes.Name as Attribuut, '' as Relatie, Attributes.Application as Applicatie, Attributes.Notes as Opmerkingen from t_object
inner join
(select t_attribute.Object_ID, t_attribute.Name, AttributeTags.Application, AttributeTags.Notes from t_attribute
inner join
(select t_attributetag.ElementID, t_attributetag.NOTES, t_object.Name as Application from t_attributetag
inner join t_object
on t_object.ea_guid = t_attributetag.VALUE) as AttributeTags
on AttributeTags.ElementID = t_attribute.ID) as Attributes
on Attributes.Object_ID = t_object.Object_ID
And here is the one for attribute tags at connectors (taking the element as starting point at which the connector starts):
select t_object.ea_guid as CLASSGUID, t_object.Object_Type as CLASSTYPE, 'Relatie' as Soort, t_object.Name as Entiteittype, '' as Attribuut, Connectors.Name as Relatie, Connectors.Application as Applicatie, Connectors.Notes as Opmerkingen from t_object
inner join
(select t_connector.Start_Object_ID, t_connector.Name, ConnectorTags.Application, ConnectorTags.Notes from t_connector
inner join
(select t_connectortag.ElementID, t_connectortag.NOTES, t_object.Name as Application from t_connectortag
inner join t_object
on t_object.ea_guid = t_connectortag.VALUE) as ConnectorTags
on ConnectorTags.ElementID = t_connector.Connector_ID) as Connectors
on Connectors.Start_Object_ID = t_object.Object_ID
« Last Edit: March 07, 2020, 03:13:59 am by Jacob Vos »
