Author Topic: Export Package to XMI / XSLT Publish  (Read 3302 times)
arphex
« on: October 09, 2012, 04:25:01 pm »
i want to create my own Stylesheet in Resources to make a post process transformation.
How can i iterate through the Export?
I saw, that all exports have a similar structure.
Now i tried this XSLT:
<xsl:stylesheet version="2.0"
                xmlns:html="http://www.w3.org/TR/REC-html40"
                xmlns:sitemap="http://www.sitemaps.org/schemas/sitemap/0.9"
                xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
<xsl:output name="text" method="text" omit-xml-declaration="yes" encoding="ISO-8859-1"/>
  <!-- Root template -->
  <xsl:template match="/">
  <xsl:result-document href="variables.py" format="text">
  <xsl:for-each select="/uml:Model/packagedElement[xmi:type='uml:Activity']">
  <xsl:value-of select="name"/>
<xsl:text><![CDATA[]]></xsl:text>
  </xsl:for-each>
  </xsl:result-document>
  </xsl:template>
</xsl:stylesheet>
I testet this here: http://xslttest.appspot.com/
When the Postprocess Transformation works i would make http://www.sparxsystems.com/enterprise_architect_user_guide/9.3/standard_uml_models/add_import_export_scripts.html
Could you please help me, because i dont know how to step through the XML structure.
Best Regards and Thanks
arpehx
