Author Topic: XSD schema generation  (Read 6172 times)
David Gomez
« on: October 09, 2012, 07:13:32 pm »
hi everybody
I just purchased a EA professional edition and was trying to generate a XSD schema from one the packages in my project. I tried to follow the instructions from the help but i just don“t see the option Code Engineering | Generate XML Schema when i right-click on the package.
Is there any previous step i need to do to see the code engineering menu?
Thank you very much in advanced.
Best Regards
RoyC
  • Read The Help!
Re: XSD schema generation
« Reply #1 on: October 10, 2012, 11:31:33 am »
Try selecting View | Workspaces and Commands, click on the Commands tab and ensure that the Complete Command Set is selected (and that all menu checkboxes are selected in the right-hand panel of the tab).
Did that fix your problem?
Best Regards, Roy
David Gomez
« Reply #2 on: October 10, 2012, 05:44:38 pm »
yes, thank you very much for quick response.
