Author Topic: Visibility of Classifiername  (Read 18096 times)
kwasposer
« on: March 11, 2020, 10:19:21 pm »
Hello, is it possible to show the classifiername in the element of the project Browser and on the diagram.
Like
time : UNIT
Re: Visibility of Classifiername
« Reply #1 on: March 11, 2020, 10:25:37 pm »
It does appear per default (V13.5). The question here: could it be suppressed somehow?
kwasposer
« Reply #2 on: March 11, 2020, 10:31:57 pm »
I ve got version v13.5.
Maybe i am doing sthing wrong. My big goal is to create an Hardware Block "Oscillator" and assign to it the value "frequency = 12 MHz" . Can you give me some hints?
So far I created a <<ModelLibrary>> pkg Quantities , pkg Units, pkg Value Types
Hope you can help me.
« Reply #3 on: March 11, 2020, 11:09:11 pm »
In short:
- create a class and add some attributes
- ctrl-drag it on a diagram
- from the dialog popping up choose Instance which will create an instance classified by that class
- from the context of the object choose Features.../Set Run State
Now you can set the run state of the attributes as desired.
kwasposer
« Reply #4 on: March 11, 2020, 11:36:06 pm »
Thank you qwerty,
I am using sysml . Unfortunatly i cannot follow your guidance .
There is no Set Run State available.
https://www.sparxsystems.com/forums/smf/index.php/topic,44138.0.html
kwasposer
« Reply #5 on: March 12, 2020, 12:17:05 am »
Hi qwerty ,
i finaly found Set Run State... on a "quantitykind"
But than i get the error
Enterprise Architect
quantityKind1 has no attribute initializers to override.
[ OK ]
« Reply #6 on: March 12, 2020, 12:24:24 am »
Please don't ask the same question in multiple threads here. That does not make you friends.
I can't help with EA's SysML add-in. But there are a couple of people here which use it.
kwasposer
« Reply #7 on: March 12, 2020, 01:30:17 am »
Sorry qwertz,
i just wanted to create a new generic topic, cause the visibility of the classifiername is a different thing
