Author Topic: Combination of landscape and portrait  (Read 5949 times)
MatthiasVDE
« on: March 13, 2020, 02:58:22 am »
I remember that there is a workaround to combine portrait and landscape templates, it was something with sections I think.
What was the correct manner to get this done?
Re: Combination of landscape and portrait
« Reply #1 on: March 13, 2020, 08:36:09 am »
Insert a section break at the end or beginning of each template that needs to change page layout.
(You remember correctly, in order to change the page layout in rtf/docx you need a new section)
Uffe
« Reply #2 on: March 13, 2020, 07:01:41 pm »
Definitely sections, and I seem to recall that the page orientation is inherited backwards -- up the document instead of down -- so if you get weird behaviour the trick might be to add a section break at the end of your differently-oriented template.
However, if it's just for diagrams it's easier (for the toolsmith) and certainly more flexible to just set the orientation in the diagram properties.
/U
MatthiasVDE
« Reply #3 on: March 13, 2020, 07:37:15 pm »
/U
How can I do this?
Uffe
« Reply #4 on: March 13, 2020, 07:52:00 pm »
In 15.0, Diagram properties -- Diagram -- Document Generation Options -- Rotate Images.
As I've noted in another thread, Divide Diagram into Multiple Pages doesn't work, but Rotate Images does.
/U
MatthiasVDE
« Reply #5 on: March 13, 2020, 07:54:24 pm »
/U
Thanks Uffe.
I'll also search if there's a way to handle this with a script during the generation of the documentation
Uffe
« Reply #6 on: March 13, 2020, 07:58:05 pm »
No worries. :)
If you use a DocumentGenerator script, it will honour the Rotate Images setting.
And here's my post on Divide Diagram, as yet unanswered.
/U
MatthiasVDE
« Reply #7 on: March 13, 2020, 08:35:41 pm »
I use the internal script environment to generate my virtual documents. So I need to investigate if I can change the rotation setting that way
MatthiasVDE
« Reply #8 on: March 17, 2020, 03:15:48 am »
No worries. :)
/U
I'm currently experimenting with the documentgenerator, but I can't find a setting to rotate the images.
steen.jensen
« Reply #9 on: March 17, 2020, 08:57:20 am »
Thw simple way is to set the Rotate on each Diagram Propertys  ;) Then when using your normal report those diagrams are Rotated and if scaling Scale to 1-page .
