Author Topic: Can't create the Element "signal" with VBScript  (Read 4470 times)
game
« on: March 16, 2020, 07:54:52 pm »
I would like to create a new element of the type "Signal" using a VBScript.
Unfortunately it always brings me the standard message "This script does not support items of this type.
Has anyone given me a code snippet in which an element of the type Signal is created?
Many greetings
Uffe
Re: Can't create the Element "signal" with VBScript
« Reply #1 on: March 16, 2020, 08:09:05 pm »
Is this a browser script? If so, have you left the default code in there?
In that case you're probably running the script with the wrong type of item selected in the browser.
/Uffe
game
« Reply #2 on: March 16, 2020, 08:29:31 pm »
Thanks for pointing out that was the first problem.
I was able to fix that now.
Now it is so that when I want to add a signal, it always brings me the error that an object is missing.
case otPackage
' Code for when a package is selected
dim ElementSignal
ElementSignal = "Signal"
dim theElement as EA.Element
set theElement = theElement.Elements.AddNew(ElementSignal, "Test")
theElement.Update()
theElement.Packages.Refresh()
Where is my error?
« Reply #3 on: March 16, 2020, 10:09:44 pm »
you have missed assigning the selected package
dim thePackage as EA.Diagram
 set thePackage = Repository.GetTreeSelectedObject()
set theElement = thePackage.Elements.AddNew("Signal Name", "Signal")
theElement.Update()
thePackage.Elements.Refresh()
game
« Reply #4 on: March 17, 2020, 12:40:42 am »
Thanks, that's how it worked now :-)
