Hi everyone,
Returning to the OP, if it's still an issue.
- Get the home users to setup their own local keystore server and transfer a licence to them temporarily (disabling it on the network version for that period0: a bit complicated and possibly not something all user's will want to do with their own home PCs,
You don't actually need to set up a local keystore for this deployment case. You can install licenses directly in the client without either a shared keystore file or a keystore server. This is the "Private Key" section of the license management GUI. The user only needs to install the EA client, not any keystore.
So you could remove a number of license keys from the keystore, e-mail one to each user and tell them to add it manually. EA does not distinguish "private" keys from "shared" (keystore) keys, each key can be used in either scenario.
If you do this, you may find you don't have enough keys for everyone -- that's the point of floating licenses, after all. So you may need to do some prioritizing.
On a separate note,
We use direct access from windows 10 to hook into the corporate network and access the licence server.
What did you do to get direct access to handle the IPV4 messaging to the licence server? (Since DA is IPV6 and the licence server isn't)
Presumably they
serve licenses from the cloud server (aka "Floating License Server"), which supports IPv6. It's only the old
keystore-only license server (aka "Keystore Service") that doesn't.
For anyone else struggling with this issue, another alternative is to go to a file based keystore for the duration. This still requires the clients to have access to the corporate network, but (assuming that this entails having access to corporate file shares) does not require a separate port to be opened in the corporate firewall. So depending on how your remote access is set up this might be a solution.
/Uffe
