Author Topic: Operation associated with the connector  (Read 7567 times)
alfons12
« on: March 17, 2020, 09:51:54 am »
How to find out guid of the operation associated with the message in the sequence diagrams and collaboration diagrams?
Re: Operation associated with the connector
« Reply #1 on: March 17, 2020, 10:58:46 am »
From my Inside book p.58:
For sequence messages which are linked to an operation there is an according tagged value operation_guid which corresponds to t_operation.ea_guid.
alfons12
« Reply #2 on: March 18, 2020, 03:37:21 am »
Awesome thank you!
Another question: in the communication diagram, where is the relationship between the association and the related collaboration stored?
« Reply #3 on: March 18, 2020, 03:48:24 am »
Can you be more specific? A communication diagram is just a diagram. So: which association and which collaboration?
alfons12
« Reply #4 on: March 18, 2020, 04:00:19 am »
1. Create communication diagram
2. Create 2 objects and insert them into the diagram
3. Crate an association between the objects
4. Righ click the association and select Add message from...
5. Double click the message (collaboration) and select an operation
The relation between the message and the operation is stored in the tagged value as you pointed out. But there must also be a link between the association and the message (collaboration).
« Reply #5 on: March 18, 2020, 07:12:17 am »
For the records: collaborations are those dashed UC ellipses which realize a UC.
3. Create an association between the objects
Nope. Objects do not have associations. They may have links, though.
alfons12
« Reply #6 on: March 18, 2020, 08:40:38 am »
When I do
and select the added message in the diagram, EA shows in the status bar that it is "Collaboration"   ::)
Ok, I see. Regarding my problem, it does not matter what type of connector it is :) The question is, if it is possible to find out which connector the message is related to.
« Reply #7 on: March 18, 2020, 09:39:27 am »
It looks like t_connector.PDATA4 contains the operation ID. (I say it looks like: I tried it on an empty model and my operation ID was "1"). In the Object Model, t_connector.PDATA4 maps to EA.Connector.MiscData(3).
alfons12
« Reply #8 on: March 22, 2020, 09:32:55 pm »
KP, it is t_connector.sourceisaggregate
« Reply #9 on: March 22, 2020, 10:27:17 pm »
sourceisaggregate holds the dropdown value from the connector property's Aggregation. 0=none, 1=shared, 2=composite.
If I got it right EA creates an entry in t_connectortag like
PropertyID;ElementID;Property;VALUE;NOTES;ea_guid;
2;6;operation_guid;{10BE20F9-6F67-4ba4-91A2-59AD27CE4E1A}; ;{2BB6F6F4-3E8F-4cdc-A07A-9C892F977E33};
where (here) {10BE20F9-6F67-4ba4-91A2-59AD27CE4E1A} matches t_operation.ea_guid of the referenced operation.
« Last Edit: March 22, 2020, 10:55:28 pm by qwerty »
alfons12
« Reply #10 on: March 23, 2020, 01:27:22 am »
Well, that's obviously true for Associations. For t_connector.connectory_type=Collaboration, the sourceisaggregate holds the ID of the association which the collaboration belongs to (created through Add message from...)
Weird, but I am just looking at it in the database.
« Reply #11 on: March 23, 2020, 04:52:41 am »
You are right. EA creates an association whose ID is stored in sourceisaggregate of the link. Why EA creates an additional association is their secret. From an UML perspective it appears to be wrong since instances are not associated but linked (a link is an instance of an association). Usually EA hides that association and that would be ok. They are free on how to implement things as long as the user gets the right representation. (Somehow when fiddling around I got the link deleted with the association showing up - well).
Anyhow, that's how it is.
