Author Topic: Automating export of a new baseline of a package  (Read 5325 times)
Luc De Graef
« on: October 16, 2012, 08:37:19 pm »
I am able to create a new baseline for a package by means of the API.
        repository.GetProjectInterface().CreateBaseline(childPackage.GetPackageGUID(), aVersion, aNote);
Is there an API foreseen to export that specific baseline?
Regards
Luc
Re: Automating export of a new baseline of a packa
« Reply #1 on: October 16, 2012, 11:44:01 pm »
I don't think there's something to export that baseline, but if you would export the package to xmi, wouldn't that have the same endresult?
If not, there have been a couple of posts lately about exporting/importing baselines. It includes getting the blob from t_document, base64 decoding, and then unzipping it.
Luc De Graef
« Reply #2 on: October 17, 2012, 01:06:40 am »
When exporting an XMI directly, and from a baseline, the 2 XMI files differ  in size (14.136 KB against 28.272KB) but this is probably some single/double byte difference.
Upon comparing however, there are some 50 differences, most of them a couple of bytes are differing inside some 'binary' clause.
I can indeed use SQL to detect the baseline...
"select  BinContent from dbo.t_document where DocType = 'Baseline'and elementId = '" + childPackage.GetPackageGUID() + "'";
I assume you refer to the forum entry: http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1348532739
But it is a pity that one needs to create a JDBC connection to the SQL Server (with Windows Authentication) specifically for that one action.
« Reply #3 on: October 17, 2012, 01:53:46 am »
You can issue the select statement via Repository.SQLQuery(sql). No need for ODBC connections.
Luc De Graef
« Reply #4 on: October 17, 2012, 02:09:56 am »
Great,
This is what I was hoping for.
Thx to query and Geert.
