Author Topic: Special chars in Simple model search  (Read 4481 times)
Guillaume
    • www.umlchannel.com
« on: March 25, 2020, 08:44:40 pm »
I have Components or other elements in a client's repository which name contains a "#" e.g. Server Bak #1, Server Bak #2
Using the Model Search (simple), I noticed that running a search with the # doesn't work (empty result list).
e.g. Server Bak returns both elements
Server Bak # doesn't return anything
# doesn't return anything either
Is there a workaround to get this to work or is it a "bug"?
Guillaume
Re: Special chars in Simple model search
« Reply #1 on: March 25, 2020, 10:14:53 pm »
Just tested it here on a local EAP and have the same effect. Names with # inside are not found. EA bug. Report it of live with it...
« Reply #2 on: March 26, 2020, 08:51:39 am »
The search you are using is using contains. Which means a sql lite. You are using an Access DB which includes # as a wildcard for numeric characters. EA apparently isn't escaping that for you.
Guillaume
« Reply #3 on: March 26, 2020, 08:19:29 pm »
I reported the bug but I can confirm that it only affects EAP/EAPX files (Ms Access). Moving to a Firebird local project for instance fixes the issue.
Guillaume
