Author Topic: SQL query for not equal Stereotype  (Read 5555 times)
dgoetz
« on: March 27, 2020, 10:14:12 pm »
I want to query for all attributes with a stereotype not equal to "abcd". I am using EA 13.5.
This query will find all attributes with stereotype "abcd":
  select *
  from t_attribute a
  where a.Stereotype like 'abcd'
The contrary search is obvious:
  select *
  from t_attribute a
  where a.Stereotype not like 'abcd'
But although there are attributes with an empty stereotype in the EA-project, the query returns no result.
Regards
Dieter
Re: SQL query for not equal Stereotype
« Reply #1 on: March 27, 2020, 10:25:57 pm »
  select *
  from t_attribute a
  select *
  from t_attribute a
Regards
Dieter
Dieter,
The contrary search is NOT obvious:
  select *
  from t_attribute a
  where a.Stereotype not like 'abcd' or a.Stereotype is Null
As a Data Architect, I HATE Nulls...
Uffe
« Reply #2 on: March 27, 2020, 10:41:03 pm »
What's that you say? Null not the same as empty?
Sir, I am shocked. Shocked!
 ;D
« Reply #3 on: March 27, 2020, 10:44:28 pm »
Just try adding
or a.Stereotype = ''
« Reply #4 on: March 27, 2020, 11:03:26 pm »
Just try adding
That's not the same thing and won't help in case of null
For large databases/complex queries it is often better to avoid "or" statements in the where clause because of performance issues.
That can be avoided by using something like
isnull(a.Stereotype,'') <> 'someStereotype' -- works for SQL Server
or
Coalesce(a.Stereotype,'') --might work for other databases
Each database has a bit it's own operator to replace null values with something else.
dgoetz
« Reply #5 on: March 27, 2020, 11:26:09 pm »
Thanks for the help. Null is working.
