Author Topic: RTF generation with dependency  (Read 3645 times)
tfcj
« on: October 18, 2012, 01:15:07 am »
sorry if its a repeated topic, but I didn't found out anything about it.
I'm generating an RTF file for my tests and I made my own template that includes requirements, inputs, outputs, etc.. all of what I want..except for dependencies.
I cannot find when editing template what should I include for dependencies to appear in RTF file. Any help?
  Telmo
Stefan Bolleininger
Re: RTF generation with dependency
« Reply #1 on: October 18, 2012, 04:37:24 am »
you find them at "connectors" in the template designer:-).
That may be the easierst possibility.
Other possibilites:
- Add the relationship matrix to the template.
- Add a model search to the report
- Create your own report generator
But i assume, you may take the first one.
Greetings
Stefan
tfcj
« Reply #2 on: October 18, 2012, 09:05:01 pm »
thanks for the reply. My problem is that when I add "Connector->Target->Element" it will should not only dependencies but also realizations. So it shows all connectors.
There isn't a way to show only dependency or to filter out realization connections, or other way?
tfcj
« Reply #3 on: October 19, 2012, 12:10:50 am »
Hi again,
I found the solution.
On Edit Template, under File -> Document Options I just need to:
Exclude connector type: Realization
Connector Direction: Source->Target
And it excludes realizations and only appears on test that are dependent.
Thanks for the help  ;)
