Author Topic: Fork/Join in Quick Linker  (Read 3651 times)
Uffe
« on: April 01, 2020, 02:31:15 am »
In a Quick Linker definition, if I specify a ControlFlow from a ForkJoinH or ForkJoinV to a stereotyped Action, it doesn't work.
If I specify the same from a stereotyped Action to a ForkJoinH or ForkJoinV, it works.
ForkJoinH,,Action,actstereo,,,,ControlFlow,,,You'll never see this,,TRUE,,TRUE,TRUE,,0,,,,,0
ForkJoinV,,Action,actstereo,,,,ControlFlow,,,Nor will you see this,,TRUE,,TRUE,TRUE,,0,,,,,0
Action,actstereo,ForkJoinH,,,,,ControlFlow,,,But you will see this,,TRUE,,TRUE,TRUE,,0,,,,,0
Action,actstereo,ForkJoinV,,,,,ControlFlow,,,As indeed you will this,,TRUE,,TRUE,TRUE,,0,,,,,0
15.1.1527.
/Uffe
Re: Fork/Join in Quick Linker
« Reply #1 on: April 01, 2020, 09:18:33 am »
Hi Uffe,
I note these (collected) examples are all ControlFlows which is a directed relationship.  Allowing for the fact that EA conflates directionality with inevitability, I notice that you don't include the direction component in your definition  ("To, From" etc.).  I ALWAYS specify it.  Give that a try and see if it helps.
Uffe
« Reply #2 on: April 01, 2020, 08:42:40 pm »
Worth a shot, but no. Neither "to" nor "directed" had any effect.
/U
