Author Topic: Wrong headings after generating document  (Read 11031 times)
MatthiasVDE
« on: April 08, 2020, 08:57:23 pm »
package >
1. Requirements (heading 1)
child packages >
1.1 {Pgk.Name} (heading 2)
< child packages
<package
When I generate this, the document shows the  package names in heading 3 instead of heading 2. To get them in heading 2, I need to put them in heading 1 in my template. Is this a bug?
it is not because of my stylesheet, because if I do it like this he will show it correctly:
1.1 The Name (heading 2)
« Last Edit: April 08, 2020, 09:00:01 pm by MatthiasVDE »
Re: Wrong headings after generating document
« Reply #1 on: April 08, 2020, 09:37:02 pm »
Matthias,
You are not supposed to put anything in the child packages node (but it might work despite that)
And yes, when going down a level, EA will automatically go to a higher heading, works as designed.
MatthiasVDE
« Reply #2 on: April 08, 2020, 09:55:03 pm »
Matthias,
Thx Geert, I didn't know that
MatthiasVDE
« Reply #3 on: April 08, 2020, 10:03:12 pm »
Another thing about this templates topic.
t
package >
     Title
< package
I repeatedly add this template to a document in order to  sum op some topics. But above the topic titles in the document, there's always a blank return/enter space. Is there any way to avoid this?
« Reply #4 on: April 08, 2020, 10:33:34 pm »
There must be. I never have additional returns in my generated documents.
Uffe
« Reply #5 on: April 08, 2020, 11:16:53 pm »
Hi Matthias,
I sometimes have issues with blank spaces, especially when there are fragments involved.
You can try moving the field labels and content opening/closing tags so they're on the same line:
    package>{Pkg.Name}<package
This can resolve some of those issues.
/Uffe
MatthiasVDE
« Reply #6 on: April 08, 2020, 11:57:54 pm »
Thanks Uffe, I'll give this a try.
Still another issue  8)
When I start with a new heading 1 title, like for example 2. Descriptions. I want that my heading 2 titles then start again with 2.1, 2.3, ... But they don't, they continue with numbering following on the ones from the previous chapter.
« Reply #7 on: April 09, 2020, 02:20:45 am »
You need to make sure all the numbered headings are in the same numberset (or whatever that was called)
MatthiasVDE
« Reply #8 on: April 09, 2020, 04:41:11 pm »
You mean 'List and Overrides' ?
« Reply #9 on: April 09, 2020, 05:52:41 pm »
Yes, that thing. They should all be part of the same list.
MatthiasVDE
« Reply #10 on: April 09, 2020, 06:10:28 pm »
For each type of heading (heading 1, heading 2 and heading 3) I tried to Edit list item and select the same list (there are a lot!!!). But it does not work, when I select a list, he sets it back to the original list.
It's hard to believe that this is the only way to get my numbering fixed?
« Reply #11 on: April 09, 2020, 06:32:12 pm »
Yes, that can be a PITA, especially if you have been messing with the stylesheet a lot.
Sometimes it's easier to start with fresh clean stylesheet.
MatthiasVDE
« Reply #12 on: April 09, 2020, 06:44:06 pm »
I created a new style sheet from scratch, in Word. Maybe that causes the problem.
« Reply #13 on: April 09, 2020, 06:58:04 pm »
Yeah, if you start from a Word document you get all kinds of messes in your EA stylesheet.
MatthiasVDE
« Reply #14 on: April 09, 2020, 07:54:20 pm »
I spent a lot of time creating that stylesheet in Word. Hopefully I can fix that heading numbering, otherwise it would be a shame.
