Author Topic: Search: Query Builder  (Read 5020 times)
vladap
« on: April 14, 2020, 07:15:52 pm »
Hi All,
I am using Query Builder for some advance searches and it works well if I write a precise select for the looking term.
My question is how to use the search bar in this case "<Search Term>" -  It doesn´t matter what I write to the search Term the result with SQL Query is always the same.
Example:
result of the SQL Query are two columns like this and I would like to use search bar to select for example only the lines with "D" result
A---B
A---B
A---C
A---C
A---D
Re: Search: Query Builder
« Reply #1 on: April 14, 2020, 07:28:21 pm »
You write something like
where t_object.Name like '<Search Term>'
EA will replace the '<Search Term>' with whatever you fill in in the search field.
vladap
« Reply #2 on: April 14, 2020, 11:20:15 pm »
it works, thanks
vladap
« Reply #3 on: April 14, 2020, 11:36:57 pm »
it works, thanks
is there a way how to share this Query between all users?
« Reply #4 on: April 14, 2020, 11:41:11 pm »
Look into %appdata%\Sparx Systems\EA\Search Data and share that.
« Reply #5 on: April 14, 2020, 11:44:42 pm »
You can share queries with individual users using the query import/export feature.
If you want to share it with all users you can include it in an MDG. I have some MDG technologies that exist only to share searches.
« Reply #6 on: April 15, 2020, 08:27:46 am »
(my emphasis) We've done the same!
« Reply #7 on: April 15, 2020, 09:20:54 am »
We do the same for internal searches that we don't think will help the wider world.
