Author Topic: Connector-to-connector connector dies with the first diagram (or package?)  (Read 3559 times)
Uffe
Hi all,
Seems the connector-to-connector functionality is broken in 15.0.
Three elements, A B and C, one connector bc between B and C.
If you draw a new connector abc from A to bc, the abc connector shows up in diagrams -- both pre-existing and subsequently created ones -- which include A, B and C. All good.
But if you then delete the diagram (? or package) where you created abc, without deleting either A, B or C, abc vanishes from all diagrams.
Needless to say, there is no mention of this behaviour in the manual.
The problem is likely that the ProxyConnector object gets deleted without checking whether it's shown in other diagrams than the ones being deleted.
Can anyone check if this is fixed in 15.1?
Cheers,
/Uffe
I just checked, and for me the connector did not get deleted (regardless of whether is was visible on any diagram)
So it seems like this problem may have been fixed.
