Author Topic: Center image in generated document  (Read 3470 times)
MatthiasVDE
« on: April 15, 2020, 06:21:19 pm »
I centered the {Diagram.DiagramImg} field in my template, but after generating the document it's always aligned left.
Am I missing something? Should this be determined in the stylesheet?
Re: Center image in generated document
« Reply #1 on: April 15, 2020, 06:23:32 pm »
Yes, we use the styles "Diagram Image" and "Diagram Label" who are center aligned for this.
MatthiasVDE
« Reply #2 on: April 15, 2020, 08:59:59 pm »
What is the appropriate way to center something? I centered it with the "center" button at the top (Paragraph) but it doesn't work.
« Reply #3 on: April 15, 2020, 09:16:39 pm »
- Open style sheet,
- Edit style (you are now in "Edit mode", notice the ever so slightly different color in the fonts) ::)
- center (with the button on top)
- click somewhere to exit "edit mode"
- save stylesheet.
To check if it worked on your template you have to update the styles.
