Author Topic: ArcGIS Extension works with the EA 9.3 TRIAL VERS?  (Read 3816 times)
TIAMARIAT
« on: October 15, 2012, 02:47:15 am »
Hello there
I was just wondering if the ArcGIS extension works with the EA 9.3 trial version. I downloaded the trial version and tried to Add the ArcGIS Model from Pattern however nothing happened?? Can anyone help here please
Thanks in advance!
Aaron B
Re: ArcGIS Extension works with the EA 9.3 TRIAL V
« Reply #1 on: October 22, 2012, 10:03:32 am »
Please make sure you have a project file open.  This menu item will not do anything unless you have a project opened.  (Note: as of the EA 10 beta, this menu option should now be disabled while no project is open.)
If you do not have an open project; create a new project, make sure you have the root model node selected in the Project Browser window, then try clicking the "Extensions | ArcGIS | Add ArcGIS model from Pattern" menu option.
When the Model Wizard dialog appears, select "ArcGIS" in the Technology list on the left side, then tick "ArcGIS Workspace" in the list on the right side and click OK.
