Author Topic: Link between project requirements and use case diagrams  (Read 22735 times)
MatthiasVDE
« on: April 17, 2020, 10:32:37 pm »
I'm busy with the setup of a repository in order to generate documentation.
For each project we have a separate project package. The starting point are requirements. We have a package called 'Requirements', with underneath four child packages (Functional Requirements, Non-Functional Requirements, Architectural Requirements and Security Requirements). In each of that packages there's a requirement diagram and a sub package with the requirement elements.
Each project can have multiple use case diagrams, so my question is: what's the best practice to link those requirements to de use case diagrams? Or better, how can I link my 'project' to the requirements and the use case diagrams? What's the best starting point to generate documentation? The project folder, or a diagram?
Re: Link between project requirements and use case diagrams
« Reply #1 on: April 17, 2020, 11:22:16 pm »
I have seen <<realize>>, <<satisfy>> and simple <<trace>> dependencies. IIRC there are also profiles supporting RM (but I'm not really in that part of the business).
jfzouain
« Reply #2 on: April 18, 2020, 04:06:27 am »
Hi
The best way to do this, is to drag and drop the requirements into the Use Case when is open in the Use case Diagram.
It gets link right away.
So when you run the Documentation or your Requirement Relationship Matrix it will show linked.
I published an eBook to do all this and much more at Leanpub.com
https://leanpub.com/uml-erpworkshop
Best regards
Jose Zouain
MatthiasVDE
« Reply #3 on: April 20, 2020, 05:04:43 pm »
Hi
Thx I'll take a look.
For now, I used composite diagrams but that isn't a preferred solution.
