Author Topic: AddNew not working for ActivityInitial?!  (Read 4247 times)
Paulus
« on: October 22, 2012, 09:23:13 pm »
I'm trying to add a startingpoint to a diagram using the VB script below, but for some reason it doesn't work the way i would expect it.
Note: the snippet works OK when adding an Action (commented line).
Is there something missing in EA or am i doing something wrong?
Paulus
' ID 1117 below belongs to an activitydiagram
sub main
      dim dgm as EA.Diagram
      set dgm = Repository.GetDiagramByID(1117)
      dim pck as EA.Package
      set pck = Repository.GetPackageByID(dgm.PackageID)
      dim elt as EA.Element
'      set elt = pck.Elements.AddNew("MyAction","Action")
      set elt = pck.Elements.AddNew("Start","ActivityInitial")
      elt.Update()
      dim dgmObject as EA.DiagramObject
      set dgmObject = dgm.diagramObjects.AddNew( "", "" )
      dgmObject.ElementID( elt.ElementID )
      dgmObject.Update()
end sub
Re: AddNew not working for ActivityInitial?!
« Reply #1 on: October 22, 2012, 09:58:20 pm »
That's because ActivityInitial is not a valid object type.
it should be a StateNode, and you should then set it's subtype to indicate that it is an initial node.
Try this (untested)
sub main
      set elt = pck.Elements.AddNew("Start","StateNode")
        elt.Subtype = 100 'for ActivityInitial
      elt.Update()
      dgmObject.Update()
end sub
Paulus
« Reply #2 on: October 22, 2012, 10:21:02 pm »
That was it  :)
Thanks Geert!
