Author Topic: How to set same object Height and Width through multiple diagrams  (Read 8430 times)
vladap
Hi All,
I am looking for a solution how to set same size for specific objects in my diagrams. Main reason is that I am putting all diagrams together on one canvas and there is starting to be visible  :)
I found here a solution using Shape Script, but its not possible to use for me. I am using mostly Archimate and stereotype is already used this notation.
Is the only option to write some JS which I will run through the diagrams?
thanks for advises
« Last Edit: April 28, 2020, 10:41:46 pm by vladap »
Re: How to set same object Height and Width through multiple diagrams
« Reply #1 on: April 29, 2020, 09:08:52 am »
It's not something that EA makes easy to do.
Options include:
  • A script eg. that copies the size of the objects to all occurrences of those objects on open diagrams.
  • Remove the object from the target diagram. (I think you need to save and re-open it as well) then copy and paste from the source diagram
  • Read the size and position from the status bar and manually position on any other diagrams (Ctrl+arrow to size, shift+arrow to move)
