Author Topic: Association IBD Enterprise Architect Example  (Read 16905 times)
kwasposer
« on: April 29, 2020, 07:41:10 am »
i tried to figure out, how they created the ibd [Automotive Domain] in the Enterprise Architect Example v15.1
If I delete the association between the sytem and the actor, i am not able to reconnect them. What am I doing wrong? Is there a way to reset the Model Example?
Re: Association IBD Enterprise Architect Example
« Reply #1 on: April 29, 2020, 07:56:58 am »
If there's a connector type that doesn't appear in the quicklinker, use the toolbox instead.
kwasposer
« Reply #2 on: April 29, 2020, 05:24:21 pm »
Thank you for the quick reply!
For practice and understanding I was deleting the Association Property between the car and the Actor.
I am not able to reconnect both, even with your advice.
What helped to  turn off "Strict connector syntax" in the Connector options.
  • Is this really the solution, cause I dont want to do anything, that is not SysML Conform?
  • Actually I need an association property not a connector. At least that it what I learn form the HSUV Example in EA.
« Last Edit: April 29, 2020, 05:45:40 pm by kwasposer »
kwasposer
« Reply #3 on: April 29, 2020, 06:05:51 pm »
I got it realized with "Reference Association"
kwasposer
« Reply #4 on: April 29, 2020, 09:57:01 pm »
I have connected the Car with an Actor using the Reference Association inside the ibd Diagram, ( see first post)
My problem: It will create connection in the bdd, too -- see picture.  What is different in the HSUV Automotive Domain?
« Last Edit: April 29, 2020, 10:02:52 pm by kwasposer »
kwasposer
« Reply #5 on: April 29, 2020, 10:06:46 pm »
I guess I have to figure out, when to use Instance or Links of a Block Element.
kwasposer
« Reply #6 on: April 29, 2020, 10:13:53 pm »
Can you help me to answer my first question of following post?
