Author Topic: How to apply Legend on Diagram Frame  (Read 6769 times)
vladap
« on: April 29, 2020, 05:51:07 pm »
Hi All,
I am wondering if there is a way how to apply Legend on Diagram Frames. I have more Diagram on one canvas for specific purpose, and on this canvas I would like to change the color little bit using Legend. I am using Tag values which should affect this change, but Diagram Frames are not affected by this Legend at all.
The Legend work in each diagram if I inserted it there, but I would like to have this color scheme only for this canvas with Diagram Frames - Is there a way how to do it?
Thanks again for you advices
Re: How to apply Legend on Diagram Frame
« Reply #1 on: April 29, 2020, 09:43:57 pm »
Not really. (AFAIK)
We solved the problem by "hiding" the legend behind one of the other items.
DavidM
« Reply #2 on: May 30, 2021, 06:16:29 pm »
I have a similar problem.
I want to use ONE diagram, as a portfolio of applications, with multiple legends attached to tags to show different heat maps. That part is done, and is simple.
Now I want to show the same diagram, with the different legends applied in a  generated report, one diagram for each legend.
Is there a way to do that please?
I thought I could embed the same diagram in different diagrams as a Frame, applying the legend that way, but as pointed out the affects of a legend in a diagram, do not propagate to the frame diagram.
« Last Edit: May 30, 2021, 06:18:01 pm by DavidM »
DeBAAT
« Reply #3 on: February 03, 2022, 09:24:43 pm »
As I would like to do just exactly this, could you elaborate on how you have done this?
Takeshi K
    • Sparx Systems Japan
« Reply #4 on: February 04, 2022, 11:18:55 am »
Hi vladap,
Can you solve with the following steps?
1. copy the Legend (currently placed on the canvas diagram) and paste it onto each framed diagram
2. enable/disable the Legend on the canvas
3. reload the canvas diagram (right-click the tab of the canvas diagram and call Reload Diagram menu item)
t-kouno
