Author Topic: Executable Statemachine using Ports  (Read 6010 times)
NikoWenz
« on: April 29, 2020, 11:40:18 pm »
anyone knows if it is possible to simualte an executable statmachine with port?
To be clear i used the Example "Simulation with Deferred Event" as reference.
Instead of connecting the classes directly, the classes should be connected via ports.
I can enable these ports inside the "executable statemachine" artifact.
But when I press CTRL+L on the connector between these ports no pop-up is opening.
Any suggestions or do I need to use the normal connector form property to property instead?
Thanks for ur time and I hope someone has investigated this already  :)
« Last Edit: April 30, 2020, 04:43:20 pm by NikoWenz »
