Author Topic: Diagram cx/cy vs diagram size  (Read 7304 times)
Uffe
« on: May 07, 2020, 06:11:00 pm »
Hi all,
What do Diagram.cx and cy actually contain?
It says they hold the X and Y dimensions (X and Y aren't used anywhere else in the GUI, API or documentation as far as I'm aware, it's all Left and Top but never mind) and default to 800 and 1100. OK fine.
But I've got a diagram where the lowest-right element is located at left 1122, top 1545 (the topmost element is at top 10 and the leftmost at left 24), and if I query the diagram properties cx=795 and cy=1138.
In other words, the diagram is larger than what's in cx and cy.
So what are these properties supposed to tell me?
/Uffe
Re: Diagram cx/cy vs diagram size
« Reply #1 on: May 07, 2020, 06:39:37 pm »
My Inside tells me: Number of pixels in X-direction used at maximum (and y respectively). No guarantee for truth, though.
For your case: bug report.
« Last Edit: May 07, 2020, 06:41:34 pm by qwerty »
Uffe
« Reply #2 on: May 07, 2020, 08:22:33 pm »
No, cx/cy seem to be fixed and unrelated to anything.
They seem to be set initially to a little less than 800 and a little more than 1130. Different in different diagrams.
They don't change with either zoom function, and they don't reflect the actual size of the diagram (as I mentioned); in fact the only way I've been able to change them is by switching the diagram to landscape. This swaps the values.
Weird.
Has anyone ever used them for anything, and if so, what?
« Reply #3 on: May 07, 2020, 08:49:46 pm »
No I don't think I have. I suspect it might be something left behind from ye olde days but no longer used now.
« Reply #4 on: May 07, 2020, 09:45:52 pm »
I looked into a repo and found most of them being 791/1134 so some "default minimum" but definitely not the used amount. EA's rendering ever since has been some voodoo where you could not realy look behind. Probably you just can't trust those numbers. However, I'll investigate a bit.
« Reply #5 on: May 07, 2020, 09:51:44 pm »
Well, it just looks like it reflects the pixel size for vertical paper orientation (A4 would be 791/1134 square px). Changing the paper also changes the px. But moving elements outside does not change anything.
(only a rough first test)
« Reply #6 on: May 07, 2020, 10:00:10 pm »
Hmm. In my repo there are a lot of similar but slightly different px-sizes. Lots of authors. So my guess would be that it depends on the printer driver that very person had installed on their machine. They deliver different resolutions. On my machine it's the above setting (I have only one printer but I'm pretty sure that's the cause). Anyhow: the numbers are pretty useless.
Uffe
« Reply #7 on: May 07, 2020, 10:28:06 pm »
I hadn't noticed the effect of the paper size. But there's no point in using cx/cy to deduce the paper size since that's in PDATA anyway.
Thanks, guys.
/U
« Reply #8 on: May 07, 2020, 10:48:00 pm »
Especially if, as it seems, the printer drivers deliver different pixel resolutions. You might find out which printer was installed for the user creating the diagram. Well, there are more useless fields carried from version to version. Those are just two of them.
« Reply #9 on: May 08, 2020, 08:27:39 am »
Years ago, we standardised these values.  We have a query that works out the closest REAL paper size and sets the values accordingly to a standard set related to the size.  We have A3H, A3V, A4H, A4V etc.
Consistency, Consistency, Consistency! TM
