Author Topic: Report generation order lost  (Read 10259 times)
PeterHeintz
« on: May 11, 2020, 11:21:02 pm »
When I generate a report, sometimes the sequence of the items (packages, elements) is mixed up.
It seems to me, that the sequence gets sometimes wrong when I start the document generation after I have modeled a longer time and that the sequence is always right when I start the document generation direct after opening the repository.
(seen in 1428 and several other builds)
Best regards,
Peter Heintz
Kay14513
Re: Report generation order lost
« Reply #1 on: September 08, 2021, 10:03:25 pm »
I have a similar problem. I generated a report due to updated notes and test results in some elements.
The order of packages and elements is reversed compared to the last time the document was generated (2018).
I used a defined document for generating the report without any changes to the defined document.
I also checked the Settings for Order. All are set to default Tree Order\Ascending.
Anyone else experiencing this and can suggest a fix?
@PeterHeintz, you never got a reply here. Did you find a way to fix this issue?
Best
Kay
PeterHeintz
« Reply #2 on: September 09, 2021, 04:44:54 pm »
I allways got the problem fixed by restarting EA and a new generation of the PDF.
Best regards,
Peter Heintz
« Reply #3 on: September 09, 2021, 05:25:24 pm »
Weird, we use a lot of document generation, but never encountered a similar problem.
