Author Topic: Profile stereotype connector labels  (Read 3737 times)
i4mdone
« on: May 14, 2020, 01:54:36 am »
I like that with Quick Linker you can define _MeaningForwards and _MeaningBackwards to indicate to the modeler the role meaning between source and target for a connector.
The question: is there a way to set the connector source and target labels to reflect the meaning and not require the modeler to type in the labels each and every time?  (also to keep things very consistent for a specific connector type)
Re: Profile stereotype connector labels
« Reply #1 on: May 14, 2020, 02:15:24 am »
I don't think so, unless you make an add-in I suppose.
« Reply #2 on: May 14, 2020, 08:37:56 am »
If you want labels to be explicitly set for all occurrences of a connector, shape script one or more labels to print that information.
i4mdone
« Reply #3 on: May 14, 2020, 09:51:01 am »
That is a great idea.  I did the following and it works:
shape targettoplabel
print("uses");
shape sourcetoplabel
print("is used by");
Follow-on question:  this may be a brainless question, but is it possible to set the target.name and source.name instead through shape script? Or is this what Geert was referring to regarding an add-in?
« Reply #4 on: May 14, 2020, 11:23:18 am »
Yes, if you actually want to assign those values to the connector you will need to use an add-in.
