Author Topic: Can't Edit Stereotype  (Read 4673 times)
jthillmn
« on: May 17, 2020, 08:37:53 am »
This is embarrassing...  I've been experimenting with v15.1 and experiencing behavior I've not seen in prior versions.
I can't change type in a name for the stereotype!
I create a class diagram, drop a class on the view and then attempt to type in a stereotype name for the class and it won't let me.  What setting might be causing this?
Re: Can't Edit Stereotype
« Reply #1 on: May 17, 2020, 09:35:35 am »
Like the rest of us, the stereotypes are "in lockdown".
In the properties window, there will be a builder ellipsis button [...] on the stereotype which will open to a dialog with the currently allowable stereotypes EA thinks can be applied to the item.
jthillmn
« Reply #2 on: May 17, 2020, 09:13:59 pm »
So the only way I can create stereotypes I want is to go through the process of pre-defining them; i.e. one can no longer just type in a stereotype name on the fly?
« Reply #3 on: May 17, 2020, 09:47:25 pm »
Yes, and most of us consider that a good thing.
A stereotypes is not something you should invent on the fly. They are extensions to the metamodel of UML. You should really think about when en why to use a certain stereotype, what the rules are, what extra properties you want to give them, etc..
They are not meant as a means to annotate or draw attention to a certain item.
jthillmn
« Reply #4 on: May 17, 2020, 11:38:09 pm »
Thanks for the responses.
