Author Topic: Input dialog with multi-line prompt  (Read 5132 times)
PeteEA
« on: May 21, 2020, 10:24:53 pm »
I'd like to create an input dialog with the prompt on multiple lines. I'm using DLGInputBox from EAScriptLib.JScript-Dialog.
I've tried including \n or String.fromCharCode(10) within the prompt parameter. Both cause the same error "Unterminated string constant" on the vbe.eval line.
As far as I can tell from VBScript info, including either CR or LF within the prompt should give a multi-line prompt
Just to be sure, I created the code manually without using the library code, with no change:
      var vbe = new ActiveXObject("ScriptControl");
      vbe.Language = "VBScript";
      DLGInputBox('A'+String.fromCharCode(10)+'B',"Title","Def");
Is there a way to get a multi-line dialog to work? I'm not restricted to this VB dialog if there is an alternative that will work (I have tried Session.Input and that silently ignores the newline.
Re: Input dialog with multi-line prompt
« Reply #1 on: May 21, 2020, 10:55:34 pm »
That makes sense.
If you look at the DLGInputBox method you see the following:
return vbe.eval( "InputBox(\"" + promptText + "\",\"" + title + "\",\"" + defaultText + "\")");
So what happens is that your input is used to create a bit of VBScirpt code, that is then executed.
So If i where to type it manually the input for vbe.eval would be
InputBox("A
B","Title","Def")
This code, when executed would indeed throw a syntax error. This is because your string that is used as promptText is not closed properly (the string doesn't continue on the next line)
If I wanted to do something like that in VBScript I would write:
InputBox("A" & vbNewLine & "B", "Title","Def")
Now I'm not familiar with JScript, but I'm guessing something like this should work:
DLGInputBox("A\" & vbNewLine & \"B","Title","Def");
PeteEA
« Reply #2 on: May 22, 2020, 12:51:06 am »
That suggestion works perfectly. I used to know a bit of VB, but it's long escaped my memory!
