Author Topic: Connector Typed by an Association  (Read 3628 times)
Miguel
« on: May 25, 2020, 08:37:34 am »
Hi everyone... I  hope someone is able to help with this one...  SysML work.  EA15.1 build 1528.
I have the following BDD:
with a "Bar" association ;-)
On the IBD, I create a connector:
But it is untyped, and there doesn't seem to be a way to specify the association model element for the type ("Type" is not selectable in Properties, and I can't find a way to do it elsewhere):
What I'm trying to do is have the connector typed by the association that is already defined, like this (which I did with Paint):
Any hints?  Thanks in advance.
« Last Edit: May 25, 2020, 08:40:53 am by Miguel »
Re: Connector Typed by an Association
« Reply #1 on: May 25, 2020, 08:51:48 am »
Select the Connector and press Ctrl+L
Miguel
« Reply #2 on: May 25, 2020, 11:16:20 am »
Haha... that worked!  Thank you.  Is there some sequence of menu options that relate to CTRL-L?  It just seems like an impossibility that I could have discovered this without your help.
Thanks, KP, and thanks for the quick response, as well.
« Reply #3 on: May 25, 2020, 11:54:42 am »
In the version I'm using, it's right-click | Advanced | Set Connector Type. I can't find it in the Properties dialog or the ribbon.
Miguel
« Reply #4 on: May 26, 2020, 12:39:57 am »
Thanks KP. that works on my version as well.
