Author Topic: Surpress Stereotype in view  (Read 2717 times)
peto
« on: May 26, 2020, 10:46:10 pm »
Working on a view where I would for the ease of non enlighted use the Appearance -> Enable Custom Draw Style to convert all visual into squared boxes. This works, it's just that the visual conversion resulted in adding the stereotype as a text to the visual. Is there a way that I can instruct the view to prevent this stereotype from being displayed?
I'm using ArchiMate visuals and the view have been defined as a Motivation viewtype.
Using EA 15.1.
Re: Surpress Stereotype in view
« Reply #1 on: May 26, 2020, 10:57:48 pm »
At the diagram properties you can suppress all stereotypes for elements. Have you tried that?
peto
« Reply #2 on: May 27, 2020, 12:45:14 am »
Once again Geert to the rescue :-) thanks. Did only look at the properties window that are displayed uppon selection and not the full property dialog (note to self - remember to do that).
