Author Topic: ArchiMate - relating Data Object to Flow relation  (Read 3391 times)
peto
« on: May 30, 2020, 12:10:35 am »
I'm Modeling a set of systems that are passing data to eachoter. According to ArchiMate it should be possible to relate a Data Object to a Flow relation. But this seems not to be the case :-(
Have any of the wizzards in here found a solution or is it just that obvious and I hvae missed it completely ...
Re: ArchiMate - relating Data Object to Flow relation
« Reply #1 on: June 01, 2020, 07:53:03 am »
There is a fix in the pipeline, but until it's released switch off strict connector syntax (ribbon|Start|Preferences|Links) and use the toolbox instead of the quicklinker.
peto
« Reply #2 on: June 02, 2020, 05:00:54 am »
Thanks :-) looking forward to that fix.
