Author Topic: Links not updating on Synscronize  (Read 3493 times)
John Kendall
« on: October 11, 2012, 05:23:11 am »
I have updated my MDG profile by adding some tagged values to a stereotype whcih extends n Information Flow.  However when I RightClick on the element in the toolbox and Synchronize Stereotype all existing links are not updated with the new tagged values.
 It works Ok for other items, just not links.  Any clues anyone as this is an urgent issue.
Many thanks
John
Re: Links not updating on Synscronize
« Reply #1 on: October 11, 2012, 11:30:15 pm »
I only tried this with element so far. You have a good chance that this is a bug which you should report (bottom of this page in the Support column).
cadalora
« Reply #2 on: October 31, 2012, 08:38:27 pm »
I have the same problem with stereotyped operations of an interface. The synchronize functionality doesn't work in this case. But when I changed something in the operation (eg add some text in the note field) then the synchronize worked. I reported this as bug, but no answer yet.
Try perhaps to change something on the information flow and start synchronize afterwards.
I think operations or Information flows are not treated in the same way as elements are.
Cheers
