Author Topic: Consitency checks and reuse  (Read 5706 times)
Viking
« on: June 03, 2020, 02:53:16 am »
Hi, I am sure that I am not the first one interested in this topic. But I did not find this topic in the forum.
I currently create an new viewpoint. Beside the notation it should provide modelling rules likes EA does it for the provided diagrams. I wonder how this is implemented in EA and if I can reuse this technology and / or models in my profile. Does EA use standard or own metamodels, OCL, etc.?
Many thanks, V.
« Last Edit: June 03, 2020, 04:14:46 am by Viking »
Uffe
Re: Consitency checks and reuse
« Reply #1 on: June 03, 2020, 07:04:57 pm »
OCL is not used. To specify permitted connectors between element types, use metarelationships or metaconstraints in your profile.
/Uffe
Viking
« Reply #2 on: June 03, 2020, 07:58:11 pm »
/Uffe
Many thanks @Uffe. Very helpful.
Does the OMG formally describe the rules of UML and BPMN ? I couldn't find anything in the Normative Machine Readable Documents.
« Reply #3 on: June 03, 2020, 08:36:21 pm »
Well, UML is normative. How tool developers realize that is different. EA isn't too bad in that respect. Alas, you have lots of people that permanently misuse UML, ignore rules and ask why they get limited all the time :-/
(I guess the same goes for BPMN since it's also now under OMG's jurisdiction.)
Viking
« Reply #4 on: June 04, 2020, 02:20:59 am »
With "Normative Machine Readable Documents" I mean the XMI-files from OMG. They contain the Elements,  Structures, etc. But I cannot find the modelling rules (like metaconstraints or OCL).
Just to make sure that there is no misunderstanding.
« Last Edit: June 04, 2020, 02:33:53 am by Viking »
« Reply #5 on: June 04, 2020, 03:35:35 am »
Have you looked at the xmi from UML 2.5?
I imported that in EA a while ago, and I do find constraints there.
For example on BroadcastSignalAction I see a constraint in OCL:
argument->size() = signal.allAttributes()->size()
Viking
« Reply #6 on: June 04, 2020, 04:03:42 am »
Great. Thank you. I will check this.
« Reply #7 on: June 04, 2020, 04:30:40 am »
I can confirm what Geert said (I have a quite recent import). However, these OCL constraints won't help you in EA unless you write your own OCL compiler. Good luck with that.
« Reply #8 on: June 04, 2020, 05:06:24 am »
That's actually quite fun. :P I did that for a small subset of OCL a while ago when we did a migration from Magicdraw to EA.
The script converted a bunch of OCL statements into a schema composer artifact.
See https://github.com/GeertBellekens/Enterprise-Architect-VBScript-Library/tree/master/Framework/OCL
« Reply #9 on: June 04, 2020, 06:31:51 am »
I think that this is fun (I wrote lots of compilers). But only if you got the time. It's definitely no free lunch here ;-)
