Author Topic: Where did the lowercase naming convention for objects come from?  (Read 2950 times)
mse
I have seen many examples of UML diagrams in multiple sources, including the UML standard and have noticed in sequence diagrams, composite structure diagrams, or even object diagrams, that the names are always abbreviated versions of the classes and always lower case. Does anyone know where this convention came from or perhaps has an idea why that was done so? Here is one example out of the SysML spec (it applies for UML as well):
https://www.omg.org/spec/SysML/1.6/PDF
See figure D.10
pcu: PowerControlUnit
epc: ElectricalPowerController
Re: Where did the lowercase naming convention for objects come from?
« Reply #1 on: June 03, 2020, 11:45:00 pm »
Well, back that history. Who cares? It's a common convention (and no law). You can make your own if you are in a certain domain but in the wide world out there you would be understood better when following the agreed convention.
« Last Edit: June 04, 2020, 09:33:22 am by KP »
« Reply #3 on: June 04, 2020, 07:52:42 am »
The last bracket was swallowed from you link.
