Author Topic: Code generation does not generate activity diagrams  (Read 4400 times)
fy1997
« on: June 08, 2020, 06:30:23 pm »
Hi!
I have a question about code generation.When I use the EAexample to generate code for activity in EAexample/softerware engineering/Java model with behaviors/TestSelectionSort,I found a problem that EA can't generate code for the activity diagram.I can't find why,does anyone know?
Thanks a lot!
jfzouain
Re: Code generation does not generate activity diagrams
« Reply #1 on: June 09, 2020, 02:34:07 am »
Hi
This one is a little bit tricky, follow this link, it may help you.
The activity diagram has to have actions and it should be under the class.
I have been working in this for the last month and it takes time to work the first time.
file:///C:/Program%20Files%20(x86)/Sparx%20Systems/User%20Guide/modeling/operationsdetail.html
Will include a chapter on code generation in my new eBook soon:
https://leanpub.com/umlerpworkshop-report-sdd
Best regards
Jose Zouain
Takeshi K
    • Sparx Systems Japan
« Reply #2 on: June 09, 2020, 11:49:10 am »
It might because of your edition. Generating behavioural code needs Unified edition or higher.
t-kouno
fy1997
« Reply #3 on: June 09, 2020, 06:16:09 pm »
You are right,thanks!
