Author Topic: How to Set Automatically Check the Diagram Properties in MDG?  (Read 2746 times)
conan
In the Diagram Property, We have to Check the Disable Fully Scoped Object Names and Fully Qualified Namespace Property. How to Set Automatically Check in the MDG?
Thank you.
Uffe
Re: How to Set Automatically Check the Diagram Properties in MDG?
« Reply #1 on: June 10, 2020, 08:44:38 pm »
It does not appear as if these options are available when using the profile helper, but Fully Scoped Object Names can be disabled by creating the special attribute styleex in the diagram definition's metaclass, and setting its initial value to NoFullScope=1;. I don't think the FQ Namespace option can be set in the MDG at all, but I may be wrong.
/Uffe
« Reply #2 on: June 10, 2020, 09:13:30 pm »
As an alternative to setting it in the MDG you might also use the model template package.
