Author Topic: Is there a tutorial on EA that focuses on modeling with SysML  (Read 4497 times)
avi10000
  • Programmer/Writer
Is there a tutorial on Spark Enterprise Architect that focuses on modeling with SysML?
And more specifically, I am interested in IBD diagrams (internal block diagrams) and activity diagrams.
Thanks.
Avraham
avi10000
  • Programmer/Writer
Re: Is there a tutorial on EA that focuses on modeling with SysML
« Reply #1 on: June 10, 2020, 09:37:01 pm »
And even more specifically, I am interested in the area of real-time systems.
avi10000
  • Programmer/Writer
« Reply #2 on: June 14, 2020, 09:24:05 pm »
Hi all,
Here is my own 2 cents to partly answer my own question. I am providing a "getting started" procedure that seems to work for me as an EA novice and for my own needs. I am doing reverse engineering, not design. Also, I already created the diagrams in Visio.  So my methodology is probably tuned for reverse engineering. I am writing it up here because maybe it will help somebody else.
1.   Start with Model Wizard.
2.   For sys engineers, choose SysML.
4.   If you want to set up a proper full project environment, then select  Basic MBSE Pattern and click Create Pattern(s).
5.   If  you are interested only in drawing a few diagrams , then select something else, e.g., select a specific diagram type and create it from the diagram type.
6.   You can also make multiple selections: Basic MBSE Pattern and also additional patterns.
7.   Create one or more BDDs at system top-level.
8.   Start creating IBDs by creating IBD canvas and then dragging in some or all of the blocks you have created in the BDDs).
9.   Connect any internal blocks. Identify and add input ports and output ports straddling the internal blocks' boundaries and the IBD diagram frame.
I would be delighted to receive any comments on the above.
Avraham
