Author Topic: How to use script to change the content of code in effect  (Read 5509 times)
fy1997
« on: June 11, 2020, 01:17:41 pm »
Does anyone knows how to change the code in effect by using script?
Re: How to use script to change the content of code in effect
« Reply #1 on: June 11, 2020, 03:49:30 pm »
I guess you mean the language: EAElement.GenType
« Reply #2 on: June 11, 2020, 04:15:41 pm »
I think he means the code you can type in the field Effect on an Action.
This is actually stored in t_xref with
Name = CustomProperties
Description = @PROP=@NAME=effect@ENDNAME;@TYPE=String@ENDTYPE;@VALU=Code in the effect field@ENDVALU;@PRMT=@ENDPRMT;@ENDPROP;
You might be able to read the field using EA.Element.CustomProperties, but I believe you'll have to update the database directly in order to edit it.
You can use the unsupported and undocumented method Repository.Execute to execute update or insert statements on the database. (at your own risk)
fy1997
« Reply #3 on: June 11, 2020, 05:06:56 pm »
I have no idea how to do it,can you give me a example?Thanks a lot!
« Reply #4 on: June 11, 2020, 05:14:07 pm »
That would be something like
Repository.Execute "update x from t_xref x set x.description = '@PROP=@NAME=effect@ENDNAME;@TYPE=String@ENDTYPE;@VALU=the new code@ENDVALU;@PRMT=@ENDPRMT;@ENDPROP;' where x.Name = 'CustomProperties' and x.Client = '" & myElement.ElementGUID & "'"
fy1997
« Reply #5 on: June 11, 2020, 05:44:19 pm »
My problem is solved,thanks a lot!
fy1997
« Reply #6 on: June 12, 2020, 06:41:20 pm »
I'm sorry to bother you again, but I have another question. When I want to change the guard of the connector line with script, what should I do?
« Reply #7 on: June 12, 2020, 06:59:06 pm »
I'm not sure, but I think you'll have to use
EA.Connector.TransitionGuard
You can find the documentation here: https://www.sparxsystems.com/enterprise_architect_user_guide/15.1/automation/connector2_2.html
